Mach Discussion => General Mach Discussion => Topic started by: moxy on April 23, 2007, 04:24:31 AM
Title: lazycam cut order
Post by: moxy on April 23, 2007, 04:24:31 AM
Hi Guys, When I post a gcode file using lazy cam I end up with quite a lot of "intercut jogging" which adds a lot of time to the job overall. I use the optomise option and that helps a bit but......... Is there a way that I can edit the cut order within lazycam or perhaps lazycam pro will include such an option. Any help?
Regards
Les
Title: Re: lazycam cut order
Post by: Brian Barker on April 23, 2007, 07:31:21 AM
Les,
This is on the books to be added... we are working on the new interface and after that we will make it so you can change the cut order
