Mach Discussion => General Mach Discussion => Topic started by: BR549 on May 14, 2015, 10:44:40 AM
Is anyone else seeing these avert#1-4 blocks on their PC when you are in the mach3 site ?
Yup. They came and went yesterday, then came back this AM and have been stuck there since.
Mozilla FF here.
Same here. Firefox also.
Actually, I don't see the ad blocks because I use an ad blocker. But I see the Artsoft title bar moving around on the screen.
Same here. Just happened tonight. Using Explorer 8.
I tried adblock BUT they are still there.
GGRRRRR , (;-) TP
I use adblocker. I don't see the adverts that BR549 refered to, but I now have the ARTSOFT logo bar fixed across the top of the page. Very annoying because it makes the viewing window lower.
I'm using Firefox, Windows 7.
I have them here, in a vertical stack, center of page. Current time 11:45 PM, pacific time, Thursday.
some wanker probley hacked it for fun
I recon we've been hackered.
yer I think they are keeping on doing it the top bar keep`s changing where stuff is and what works more than likely to take M4 whats been done already and cracked A HOLE`S
;D No worries guys, its not being hacked but it is changing. You should be seeing 4 place holders for some small advertisements that will be listed soon.
:) OK, they just moved up to a better place but the entire upper block is stuck and does not scroll up out of the way like it used to.
Is this a new "stuck in place" ad campaign ?
Russ :)
Yeah Russ, They are playing with it now. Not sure what it will be when finished.
