Mach Discussion => General Mach Discussion => Topic started by: mike^3 on May 14, 2015, 09:42:39 AM
Hello everyone! ??? ??? ???
I just picked up a cnc plasma cutter that needs a new control, but I have one question about the THC. I am very familiar with wiring and can easily wire the rest of the machine.
The Torch Height Contol has a 24vdc motor for moving the z axis up and down, it is not a stepper motor. Can I use this with mach 3 for the THC? I am not sure how to set up the configurations either.
Any help would be greatly appreciated!
Well it is not IMPOSSIBLE but would be a lot of experimenting. You would have to monitor the step/dir linesfor z and it active activate a set of relays to run forward/reverse the DC motor when under THC control.
The remaining problem is you have ZERO control of height when the THC is not controlling.
Chances are good the results would be less than desirable.
(:-) TP
Dang thats what I thought, well ill have to convert it to stepper control :)
Thanks!
Also can you recommend a good thc?
In the USA, CandCNC
In the UK RazorDance
Yes, it is possible (with your DC Motor) with Stand Alone control cards and Capacitive THC from www.cnc4pc.com
