Mach Discussion => Mach4 General Discussion => Topic started by: dude1 on May 02, 2015, 04:12:40 AM
I am going through the M4 scripting manual have got up to the automatic tool height section
how do i set the getregiser function in a M code header file
its this bit
A brief run through: As before the first step in the script is getting and defining necessary variables and the current state of the machine. Register values are retrieved using the GetRegister() function created in section 4.3. It is not defined in this script so it must be defined in an M code header file or a loaded module to allow access to it.
I think I have everything else working
You may have to copy/paste the GetRegister() function from the header file and put it directly into your script.
At least in the scripter, when debugging, it errors out and will not "find" that function in the header file.
It MAY work if calling from the MDI, but, I have not tested that.
ok I tryed adding this it did not work
function GetRegister(regname)
local hreg = mc.mcRegGetHandle(inst, string.format("iRegs0/%s", regname))
return mc.mcRegGetValueString(hreg)
end
is there a way of defining it as a macro
-- Auto Tool Setting Macro
Requires the following instance registers to be defined
TS_XPos-----------X position of probe (machine position)
TS_YPos-----------Y position of probe (machine position)
TS_Type-----------Offset type (1 or 2)
TS_TouchPos-------Z position of touch off surface (machine position)
TS_ProbeH---------Height of probe above touch off surface
TS_DefaultL-------Default tool length guess
TS_Retract--------Retract distance after probe touch
Offset Type 1-----Length of tool from gauge line to tip
Offset Type 2-----Distance from tip of tool to the touch position
--The function GetRegister() must be defined for use by macros (its this bit I cant work out how to do)
Just in case you did not, you have to have the register defined, before you call it.........
Scott
thats the bit I dont now how to do
at a guess
function GetRegister(TS_XPos)
local hreg = mc.mcRegGetHandle(inst, string.format("iRegs0/%s",TS_XPos ))
end
I don't know if you can define them through statements but you can define them by opening up Regfile and adding them. That's how I'm doing it.
Peter
not quite sure how to do that ever
I tried adding them to regfile it did not work
I think I have to do what`s at the bottom of page 16 top of 17 in the scripting manual
you have to pass: TS_XPos, as a string: "TS_XPos"
Scott
Sorry, I thought you said they weren't defined yet. Once they are, you can follow the instructions to access them as you say.
Peter
I can find them its just the code needs them available for m code I worked out how to do it for one not all of them to together
this is what i have come up with probley wrong
function VariableParamFunc(...)
local TS_XPos = 0; local TS_YPos = 0; local TS_Type = 0; local TS_TouchPos = 0; local mInst = 0;
local inst = mc.mcGetInstance(mInst);
TS_XPos, TS_YPos, TS_Type, TS_TouchPos = select(1, ...);
if TS_XPos == nil then TS_XPos = "nil"; end
if TS_YPos == nil then TS_YPos = "nil"; end
if TS_Type == nil then TS_Type = "nil"; end
if TS_TouchPos == nil then TS_TouchPos = "nil"; end
mc.mcCntlSetLastError( inst,
" TS_XPos = " .. tostring( TS_XPos)..
" TS_YPos = ".. tostring(TS_YPos)..
" TS_Type = ".. tostring(TS_Type)..
" TS_TouchPos = ".. tostring(TS_TouchPos));
end
if (mc.mcInEditor() == 1) then
VariableParamFunc();
VariableParamFunc(2,3,4);
end
--You can pass as many params as you want, by putting in the function
--variables that get them via the order them come in at.
--this example handles three.
--Scott
right this lua is a pita
what I think I need to do is use this
end
and have it like this
local hreg = mc.mcRegGetHandle(inst, string.format("iRegs0/%s, TS_XPos",10))
end
function GetRegister(TS_YPos)
local hreg = mc.mcRegGetHandle(inst, string.format("iRegs0/%s, TS_Pos",10))
so on
then end with this
end
it compiles and runs and debugs with no problem
then at top of m1005 put in path to it or not
but when I run m1005 it compiles but does not run as it cant find the Register`s
I have put them in as iregs and gregs that did fa I could find and read them using one of Scott examples this one Quicky Wizard and/or Macro variable value viewer function.
the thing I am getting stuck on is m1005 finding them I meant to put them in a use macro or module.
with what I have put in here how wrong am I
also Scott is there something you or ya bro have posted that is the correct way of doing just pointers please, if I can`t work this out by the end of the week I might ask for the answer
for the time being I will just use the macro b to do tool height probing it works but I would rather use the code in the manual it`s a bit safer
and i will be doing the first cut with M4 Friday or monday just got to fix a bobo
You may have already done this but,
In the Register plugin, in the "instance" tab, that is where you add your register name and the value of that register.
i.e.
you will have under the "Name" and "Initial Value" columb:
TS_XPos 2.0
TS_YPos 1.5
etc....
Then in your code that you getting those values:
end
local TS_XPosVal = tonumber(GetRegister("TS_XPos"));
local TS_YPosVal = tonumber(GetRegister("TS_YPos"));
etc.
Scott
thank`s scott my brains burt for to day I will get back to it tommrow I have done half of that i have put the registers in
then i will do what you have suggested.
I always wondered what is the difference between global registers and instance registers, when to use one or the other, etc ; i guess most programmers know about that , but is there a simple explanation somewhere for regular users ?
this is what I have so far its still not working
local macroname = "m1005"
local rc
end
local TS_XPosVal = tostring(GetRegister("TS_XPos"));
local YPosVal = tostring(GetRegister("TS_YPos"));
local TypeVal = tostring(GetRegister("TS_Type"));
local TouchPosVal = tostring(GetRegister("TS_TouchPos"));
local ProbeHVal = tostring(GetRegister("TS_ProbeH"));
local RetractLVal = tostring(GetRegister("TS_RetractL"));
local DefaultVal = tostring(GetRegister("TS_DefaultL"));
--regval = GetRegister("TS_Type")
--wx.wxMessageBox(regval)
GetRegister ();
end
I have put them in the Register and can call them using
I keep getting this
[string "C:\Mach4Hobby\Macros\m1005.mcs"]:34: attempt to call global 'GetRegister' (a nil value)
stack traceback:
[string "C:\Mach4Hobby\Macros\m1005.mcs"]:34: in function 'm1005'
[string "C:\Mach4Hobby\Macros\m1005.mcs"]:103: in main chunk
mcLua ERROR: Lua: Error while running chunk
Try this instead:
function m1005()
--local macroname = "m1005"
local rc;
local inst = mc.mcGetInstance();
local hreg = mc.mcRegGetHandle(inst, string.format("iRegs0/%s", regname));
return mc.mcRegGetValueString(hreg);
end
--regval = GetRegister("TS_Type");
--wx.wxMessageBox(regval);
end
m1005();
end
I should of been more correct I get this with the m1005 tool height probing from the scripting manual
I keep getting this
stack traceback:
having the reg in reg or the macro I can call them but the tool height probing macro cant find them
do i need to put in a address for this
unction m1005()
local rc;
end
end
m1005();
end
so the tool height probing macro can find it what is m1005 from the manual
I have played some more I add this into the Auto Tool Setting Macro from the manual
local rc;
end
now the Get touch off parameters work but when it gets to the Check Probe part it fails it comes up with this
[string "C:\Mach4Hobby\Macros\m1005.mcs"]:48: wxLua: Expected a 'number' for parameter 2, but got a 'nil'.
Function called: 'mcSignalGetHandle(number, nil)'
01. mcSignalGetHandle(number, number, lightuserdata)
stack traceback:
[C]: in function 'mcSignalGetHandle'
[string "C:\Mach4Hobby\Macros\m1005.mcs"]:48: in function 'm1005'
[string "C:\Mach4Hobby\Macros\m1005.mcs"]:109: in main chunk
I am running it in sim I have defind a probe input
Function called: 'mcSignalGetHandle(number, nil)'--is your error
the "nil" is the parameter 2, you need to have something like: mc.ISIG_INPUT1 in there.
Scott
I think they did this with bits missing so people will learn a thing or two more than just copy and past code to its correct spot it`s not fun but I know how it was for you and ya bro to do now.
thanks for the help scott
thank you very much Scott I I think i got it working your hints are very good now to the next one
