Mach Discussion => General Mach Discussion => Topic started by: jve on March 25, 2015, 12:55:16 PM
Title: spindle problem
Post by: jve on March 25, 2015, 12:55:16 PM
hi all,
i been using mach 3 for several times and today i tried to make a spindle working 0 to 10v with a csmio controller i manage to make it working with no problems it is varying but this is the most strange thing that i have when you type in the mdi m3 s1000 the spindle starts and it will run 1000 but if i type 2000 the spindle will keep 1000 then when i press reset spindle over ride it will go 2000 so basically i have to press the reset spindle override to ghange the spindle speed after i type in mdi or in g code  file
do i am missing something ????????
Title: Re: spindle problem
Post by: TPS on March 25, 2015, 01:01:23 PM
Hi jve,
have you entered S2000 in the MDI line ?
Thomas
Post by: jve on March 25, 2015, 01:07:21 PM
yes but it does not go to S2000 but after i press the reset spindle override and it works some more strange thing is that if i move the spindle override slider to increase the speed it works too but if i type in the MDI it does not
Post by: TPS on March 25, 2015, 01:13:13 PM
ok,
never tryed to change spindle Speed during spindle was on. allways in combination with M3.
sorry no further idea.
Thomas
