Mach Discussion => General Mach Discussion => Topic started by: f_armer on March 08, 2015, 09:03:24 PM
Is there any possible way to adjust the Z while cutting? I have an oxy fuel setup and I have set the THC up and down to emulate on the keyboard, and it works, but just wondered if it was at all possible to have the xbox controller do it?
Can you assign hotkeys in the Xbox ??? If so then pick the SAME hotkeys that you work the THC up<>down with.
Thats exactly what I was hoping I could do. There are no choices in the drop down menus though. And I'm not sure where else to look.
was hoping someone on here had figured it out.
I would check the config for the plugin. That is where you maybe able to setup a hotkey.
