Mach Discussion => General Mach Discussion => Topic started by: pminmo on April 12, 2007, 02:26:53 PM
Title: Machine configuration file
Post by: pminmo on April 12, 2007, 02:26:53 PM
If you want to move a machine to another computer, is there a file that has the machine definition that needs to be copied, or do you have to set it up all over again?
Title: Re: Machine configuration file
Post by: Brian Barker on April 12, 2007, 03:03:34 PM
you need to move over you XML file. Most use the Mach3Mill.xml
thanks
Brian
Post by: Hood on April 12, 2007, 05:17:24 PM
Also make sure you copy your Mach1Lic.dat and if you use keygrabber or have a custom screen or custom macros you will need to save them.
