Mach Discussion => Feature Requests => Topic started by: justjuha on February 27, 2015, 06:04:09 AM
Title: Signal matrix for inputs & outputs
Post by: justjuha on February 27, 2015, 06:04:09 AM
Hello!
I came accross of need to reroute input signals to outputs (see the topic (http://www.machsupport.com/forum/index.php/topic,29178.0.html))
What do you think about an idea to have ins & outs in a matrix, in a sort of table having columns and rows where you can route signals just by having signal intersections checked? And even better, if you could have some logic implemented, a least AND and OR (maybe also NAND, NOR etc) would be good to have.
All configuration that is already now included separately for inputs and outputs could be merged into a same table (e.g. inputs in columns and outputs in rowss) and signal connections added in to the matrix.
Maybe you could get some idea about suggestion by looking how signal matrix has been done in ABB's PCM600 protection relay setting tool (https://www.youtube.com/watch?v=A0wwUMA1OAM&index=1&list=PL141A93354E209319).
Juha
Title: Re: Signal matrix for inputs & outputs
Post by: BR549 on February 27, 2015, 07:54:39 AM
Might want to consider learning the tools you already have (;-) Mach3 CB, Macropump,Brains,Plugins,OEMtriggers, etc ,etc AS there will be NO MORE improvements or FIXES for Mach3.
Post by: justjuha on March 01, 2015, 09:18:18 AM
I was trying to add a button on to the screen for the function I was looking for. In fact I got it done (that it almost works as intended).
To get this done, I obviously needed a screen editor (http://www.machsupport.com/wp-content/uploads/2013/04/Mach3Screen.zip).
By using a program, I got the button added, but on saving and opening screen on Mach, the page (1st, Program run) got totally mixed up. All buttons and DRO and so were almost randomly pleced on the screen. What am I doing wrong?
There are lot of things to study in the recommendation list referred as I do not even know what is Mach3 CB. It might be obvious for some, but for dudes like me, uhh...
Cheers,
Juha
Post by: BR549 on March 01, 2015, 03:31:05 PM
Mach CB is Cypress Basic a laungage like Visual basic. The CB editor is build into Mach3  What you need for screen work would be Mach Screen.
(;)TP
