Mach Discussion => General Mach Discussion => Topic started by: dgalaxy on April 11, 2007, 03:59:44 PM
Title: BOBCAD MACH3 post
Post by: dgalaxy on April 11, 2007, 03:59:44 PM
Could somebody please load this code in there mach3 and see if there getting a bunch of loop de loos  circles see if im crazy.
when i  create the code in Sheetcam everything is fine .    when i take the same drawing and make some code with bobcad i get a bunch of  circles that mach will cut just wondering if it is operator error or my post is screwed up. because if i generate some code with the bobcad plasma post the circles are not there but this is for my mill
Thanks John
i think i put this in the wrong catagory im  terribly sorry probably should have been in third party software
Title: Re: BOBCAD MACH3 post
Post by: Hood on April 11, 2007, 06:06:04 PM
Try setting the IJ mode to the opposite of what it is now, you will find it on the General Config page.
Post by: dgalaxy on April 11, 2007, 06:35:49 PM
Ya Hood i tried that and all that does is give me a whole bunch of circles  does it show 4 little circles on your computer
Post by: dgalaxy on April 11, 2007, 06:38:34 PM
what does that mean if most of the code is blue and the 4 little circles are purple thats the way it is showing up on mine
Post by: Chaoticone on April 11, 2007, 07:41:15 PM
This is what I get. The reason for the differnet colors is just another good feature of Mach. Do these help?
Post by: dgalaxy on April 11, 2007, 07:47:30 PM
ya thats right do you see those circles like on the bottom of his chest and his feet and legs" these arent supposed to be there". well i must not be crazy. Mach is following this.  when i build the code in sheetcam it does not make those circles. so am i right it must be the bobcad post  if i use the bobcad plasma post it doesnt make those circles either what do ya think? Chaoticone
John
Post by: Chaoticone on April 11, 2007, 07:51:28 PM
I think it must be in the post processor. When you generate the code do you have an option of doing arc leadins?
Post by: dgalaxy on April 11, 2007, 07:59:33 PM
 This for my mill i cant see anything ive opened everybox  and  if i switch to plasma post instead of mill there are no circles.  i geuss ill have to call them. Thanks Brett so much  for looking at this for me!!!!!   I appreciate it a whole bunch you have no idea.
John
Post by: Chaoticone on April 11, 2007, 08:10:35 PM
Your welcome John, I wish I could do more.
Post by: Graham Waterworth on April 12, 2007, 02:32:44 AM
In the BOBCAD nc code viewer on the menu setup is Driver setup, on the general tab try changing the MAX CIRCULAR MOVEMENT options and re-generate the code.
Also turn off the XY show only changed options.
I think its got something to do with the G02's not having X and Y figures.
Graham.
Post by: dgalaxy on April 12, 2007, 09:59:46 AM
ill give it a whirl  and get back to ya
Post by: dgalaxy on April 12, 2007, 10:12:49 AM
Holy Smokes Got it   Thanks Graham Brett and Hood.   Graham got me the Hook up i didnt change the circular motion i just uncheck the x and y toggle  Once again Thanks Graham
John
