General CNC Chat => Show"N"Tell ( What you have made with your CNC machine.) => Topic started by: madeintheshed on February 22, 2015, 03:21:57 AM
Title: Night Lite
Post by: madeintheshed on February 22, 2015, 03:21:57 AM
Here's a niteilight I made our newborn Nephew....
Title: Re: Night Lite
Post by: Tweakie.CNC on February 22, 2015, 10:17:26 AM
Very nice work madeintheshed.
Post by: DICKEYBIRD on February 25, 2015, 05:05:05 PM
Very nice!  Can you pass on some info as to how you did that?  What type of plastic, spindle speed, how do you get the polished edges, light source, etc....please. ;D
I have an old CNC router but shudder to think what a mess I'd make with its 23K rpm trim router.
Post by: madeintheshed on March 21, 2015, 07:20:03 AM
10mm thick clear acrylic. I think it was around 20K spindle speed with a 1/8" upcut 2 flute carbide bit 3mm DOC. I left 0.2mm all the way around both inside and out and then did a final pass at full depth. I did the inside first, then re clamped though those cutouts and then did the outside.
Finishing the edges was done by flame polishing. I used a small butane blowtorch - about the size of a cigarette lighter - that gives a blue flame. A quick pass along the edge and it melts the surface. Pretty cool to watch it go from white to clear. Took very little practice to get the technique.
Lighting is via blue LED's inserted into 5mm holes drilled up from the bottom of each letter. Powered by a 3v battery pack with a switch.
