Mach Discussion => General Mach Discussion => Topic started by: Damin69 on February 21, 2015, 07:16:11 PM
Title: AutoZ Issue
Post by: Damin69 on February 21, 2015, 07:16:11 PM
Auto Z was working just fine. Now it will not work properly. When I click on my auto z button the bit comes down about 1/8" then pulls up the the retract distance and says that Z is Zeroed. But it is not. I have tried redoing the script using a completely different script same issue. I have rebooted and restarted everything does it every time. Any suggestions?
Title: Re: AutoZ Issue
Post by: ger21 on February 21, 2015, 10:00:19 PM
Possibly noise triggering the input.
Post by: Damin69 on February 21, 2015, 10:07:25 PM
How DO I filter out noise if that is what it is? Or find out if it is noise?
Post by: dude1 on February 21, 2015, 10:15:03 PM
one way to find noise is with a radio on fm have it tuned into a station stick it on the machine and if it goes all statistic you have noise that's a ruff way to do it it works thoe,
also inspect all the wiring you could have a bad wire.
there are lots of things that can make noise happen those two things are quick checks
Post by: ger21 on February 21, 2015, 10:16:33 PM
A lot of people add a capacitor across the input.
Post by: Damin69 on February 22, 2015, 01:22:38 PM
Thanks for  info. The cap across the input did the trick.
