Mach Discussion => VB and the development of wizards => Topic started by: Oldraven on February 20, 2015, 04:36:49 AM
Title: need help!
Post by: Oldraven on February 20, 2015, 04:36:49 AM
Hello all,
I really could use some help with one command in the VB script below.
This statement works but also seeds the X- and Z-axes DRO's with random digits!
Call SetOEMDRO(824,number)                  'Set tool # in DRO
Why ??
I am working on this for almost a week now.
For the rest the script works OK.
Jos
'REM _________Script to advance ATC/Turret 1 position.____________
  maxtool = 6                        '# of tools in turret
  extraAngle = 6                             'Extra angle added to turret rotation
  round = 360                        'One turn in degrees of turret
  oldtool = getcurrenttool                       'Tool # before rotation
  newtool = GetOEMDRO(824)               'Get Tool #
  Angle = round/maxtool                                     'Angle of rotation i.e. 60 degrees
  number = GetOEMDro(824)                                 'Get Tool #
Code "G91"                        'Incremental Distance Mode
If GetOEMDRO(824) = 0 Or GetOEMDRO(824) >6 Then
   number1 = Question("What is current tool # ?")
   Call SetOEMDRO(824,number1)
   Call SetOemDro(803,number1*round/maxtool) '803 = A Turret DRO
   Exit Sub
End If
number=number+1                                            'add 1 to the #
If nummer>maxtool Then number=1                        'check if tool # is 6
'After executing the next line the X- and Z- DRO's display random figures.
'I do not know why.
                                          'now calculate the rotation angle of turret
If number=1 Then Call SetOemDro(803,0)
ToolChange = GetOEMDRO(803)                    'Get A position
ToolChange = (round/maxtool)+extraAngle                  'Tool-change turret 60 + 6 CW
Code "G0 A" & ToolChange                                'execute rotation CW
code "G0 A" & -6                          '6 steps CCW
While IsMoving()
Wend
Call SetOEMDro(803,((number-1)*round/maxtool))
Code "G90"                             'back to Absolute Distance Mode
Title: Re: need help!
Post by: BR549 on February 20, 2015, 11:55:49 AM
Yo cannot use the word ROUND as a variable it is an internal math function. Change that word to something else. I changed it to Turn.
  Turn = 360                        'One turn in degrees of turret
  Angle = Turn/maxtool                                     'Angle of rotation i.e. 60 degrees
   Call SetOemDro(803,number1*Turn/maxtool) '803 = A Turret DRO
   Exit Sub
End If
'I do not know why.
ToolChange = (Turn/maxtool)+extraAngle                  'Tool-change turret 60 + 6 CW
While IsMoving()
Wend
Call SetOEMDro(803,((number-1)*Turn/maxtool))
Title: Re: need help! SOLVED!
Post by: Oldraven on February 21, 2015, 03:15:16 AM
You cannot use the word ROUND as a variable it is an internal math function. Change that word to something else. I changed it to Turn.
Thanks for this hint.
I am Dutch, hence the mistake in translating the dutch word "rond"to "round".
I did not know that Round is an internal function.
However, the strange problem seems to be solved.
I decided to create a new profile, from the one that gave me so much trouble, in order to work on this new profile with Machscreen.
Before doing any changes to to lset file I tested the new profile.
After copying the M6Start.m1s file in the profile folder all worked like a charm.
The X- and Z DRO's stay on zero!! no more jumping around at random.
It seems that copying and thus creating a new profile Mach3 corrected a mistake somewhere.
Jos
