Mach Discussion => General Mach Discussion => Topic started by: jeff johnson on February 05, 2015, 12:04:17 PM
On my screen I have 2 AUX Output buttons, that trigger 2 relays. AUX 1 is set to output 1 and automatically triggers when I hit Start. Its a CANDCNC electronics with 2, 110v outputs controlled by relays. How do I get the other relay, which is set to output 2 to also trigger at Start? I can trigger it on by clicking the on screen button, but I need it to start also at Start to trigger the VFD controlled Spindle. Do I edit a line in my Post Processor or do I set something in Mach? I am sorry but I havent messed with Mach for about a year and I forgot what little I did know, and I tried searching but I guess I didnt know how to word it.
If they are VB buttons, compare the scripts.
Make 2 like 1.
Under OPERATOR, click Edit Btton Scripts. They will blink if they are script buttons. Click on them to see the innards.
I tried this just now and they are not VB Buttons.
Could they be a G Code in the Post Processor?
Open them up with Screen4 and see what is assigned to them.
I know that there is an M03 code in my PP that turns on relay 1 and I am thinking M07 may turn on relay 2. I will try the screen 4 look. Thanks
You might change the START button to VB to activate the outputs as well as start the cycle.
Maybe it is this way for output 1 already ?
Easy enough to check.
Ok you lost me on changing the start button to VB . I looked at both tabs in Screen 4, relay 1 is an OEM code 110, and relay 2 is an OEM code 113....????? What ever that means.
Do you mean Cycle Start ??? or Spindle Start ??
If Spindle, it would probably all be in the M3 macro.
It triggers relay 1 when I hit cycle start. I can manually hit them both at anytime with the mouse and trigger them. I think its controlled now under "spindle setup". In my PP i see the M3 command. So just for simplicity couldnt I edit my PP and have it trigger the 2nd relay with M7 or M8 OEM code 113 or 114?
Ok I got it to trigger by editing my PP. I added the M7 code. Thanks for all your help. Now if you know what code I can use to make everything pause while the spindle gets to speed ?
Config/ports and pins/spindle setup
