Mach Discussion => General Mach Discussion => Topic started by: Frank1959 on January 16, 2015, 04:46:20 AM
Hia all,
When I Reference my A or X axis, either in Diagnostics or using Ref All Axis, both my X axis and my A axis usually overrun the Home switch, because both axis move/spin quite quickly, causing the Limit switch (on the X axis) to trip.
On the A axis, the result is that sometimes it homes on one side of the steel slug bolted to the chuck, that passes in front of the proximity switch, but if it overruns, it homes on the other side, giving about a 30 degree difference in the chuck position.
I´ve just read on page 4-10 of the MACH Manual Rev 1.84-A2, that the axis will travel “at a selectable low speed”.
Can anyone tell me where that parameter is selected?
Regards and thanks,
Frank
Config menu then Homing and Limits, you can set the speed there as a 5 of the rapid for that axis.
"Config menu then Homing and Limits, you can set the speed there as a % of the rapid for that axis.
Hood"
(intermittent Shift key) :)
Russ
Nah, frozen bloody fingers, its like the ice age all over again in the workshop.
Many thanks to both Hood and his frozen fingers ;D and Overloaded for being there too.
Did that, works great !!!
Frank.
www.franknorton.com
