Third party software and hardware support forums. => PoKeys => Topic started by: Weerasak on January 14, 2015, 06:54:01 PM
Pokeys57E with firmware v3.1.45, does not stop generating charge pump signal when it lost connection. Can this be fixed in future version?
Weerasak
Enable the 'Pulse engine' option in Peripherals > Failsafe settings in PoKeys application set set the failsafe timeout.
Thank you for pointing it out,
Please consider to put this option in Pulse engine tab in Mach3 plugin also. Configure all options from one place, make it easy to use.
Currently, I only use PoKeys application for setting IP address, upgrading firmware and clearing all setup.
