Mach Discussion => General Mach Discussion => Topic started by: renklaufs on January 09, 2015, 03:43:24 PM
Title: setting zero doesn't touch work
Post by: renklaufs on January 09, 2015, 03:43:24 PM
Hi
I have recently developed a problem with my CNC machine, using Mach 3, when I zero the z axis on top of the workpiece and run the programme the z axis wont come down to touch the work.
the programme limits change to keep it from going down far enough. How can I cure this problem. I use V Carve Pro to generate the G code.
Thanks in advance
Renklaufs
Title: Re: setting zero doesn't touch work
Post by: Hood on January 10, 2015, 05:51:38 AM
Attach your xml and your problematic G code.
Post by: renklaufs on January 10, 2015, 06:33:31 AM
Attached gcode file and xml file
Any help would be appreciated as everything was working fine until this job.
Renklaufs
Post by: Hood on January 10, 2015, 07:03:35 AM
Looks like your code has Z10 as the surface of the material, maybe you set that as the surface in your CAM.
If you touch off the top of the material and instead of setting the Z zero you set it to 10 it should work.
Best to sort out in CAM however.
Post by: renklaufs on January 10, 2015, 09:34:49 AM
Sorted.
Looked at CAM and changed setup. Great to have another pair of eyes.
Thanks again.
Post by: Hood on January 11, 2015, 04:16:50 AM
No problem :)
