Mach Discussion => General Mach Discussion => Topic started by: NormB on December 27, 2014, 08:40:01 AM
I finally got my DRO,s in agreemjent but when I move to a ne location to set 0,0 for a job the Zero key does not work. What setting do I need to change to allow me to reset the work 0,0 to the new location?
Make sure Machine Coordinates are not turned on.
Machine coordinates when homing gets reset to 0 but the poart does not. When I move to the position I want to be zero I am not able to with the buttons it's like they are locked out.
I think I just found the problem, Persistent DRO and Persistent offsets were both checked under general configuration. After unchecking them I am ab le to reset the DRO's to zero. Then when I check machine coordinates it showes exactly where I am on the table.
Well part of it anyway. Now I can reset only if I hit reset then zero the DRO's after homing. This is strange
