Mach Discussion => Brains Development => Topic started by: Jimmyalenius on December 26, 2014, 02:39:41 PM
Seems that I got no Brains folder in my Mach3 folder. Is it possible to add that later, or do I have to reinstall the program?
Regards / Jimmy
yes just make a folder
I tried that but Mach3 don't load brains that's in that folder.
did you label it Brains.
if that did not work reload M3 the Brains folder should of all ready been there
Hi! My installation/Mach3-folder just got this folders:
GCode
LCamSamples
Shapes
So I made a "Brains" folder, but non of the brains files in that folder show up in the "Brain Control". And I have restarted my computer several times. The only Brain file that I can see in the Brain Control is "ModIOMPG.brn", but that one is not on my computer harddrive.
What version of Mach3 is this?
Where did you install it to?
Sounds like your looking at the wrong folder.
Yes Gerry, you are right. For some reason I got two Mach3 folders, and when I searched for "ModIOMPG.brn" I couldn't find it anywere. Thanks for pointing that out.
buenos dias
donde puedo buscar un manual de brains
buenos dias
http://www.machsupport.com/videos/
es posible algun fichero en pdf para verlo mejor porque mi ingles es mejor en papel
http://www.machsupport.com/forum/index.php/topic,8211.0.html
donde puedo buscar un ejemplo para un volante portatil en brains
un selector para 3 ejes y un encoder para el volante
For those who do not use Google Translate:-
"Where I can find an example for a portable steering wheel brains
a selector for 3-axis and an encoder for the wheel"
