Mach Discussion => General Mach Discussion => Topic started by: manine on March 01, 2006, 09:58:07 AM
Hello all
I just upgraded Mach3 from 1.84.000 to 1.84.001 in hopes of getting the "cut rectangle" Newfangled wizard to work right. Now my motors don't move! All the settings seem to be intact, Jog mode is on.
-Matt
Check the jog mode :)
Jog mode is on, doesn't work in step or cont
The coordinates move on the screen... not on the machine.
Mach 2 works fine, I finished building my little project with New Fangled wizards. I have to load the code into Mach 2- the problem I had with the rectangle wizard disappeared when I cut with Mach2!
-Matt
Sound like there is a ports and pins config problem...
