Mach Discussion => General Mach Discussion => Topic started by: MavStone on December 10, 2014, 10:13:02 AM
I want to add a button to my screen set to pull up and run the Newfangled Turn Wizard. I have an OEM-code 230 (Display Wizard selection window) on my screen which does open the wizard selection window. However, went I press my OEM-code 321 button it doen't do anything.
It seem like 321 should open the wizard and run it.
Thx Mav
You can use a VB Script in the button to call the wizard by name and run it. Use the LoadWizard function.
Thanks Gerry,
I'll give that a try.
Try either :
LoadWizard(“NFSturn”)
or
LoadWizard “NFSturn”
Make sure the name is correct. I don't have Mach3 installed here, so I can't check right now.
Wow......... Thanks Gerry.
LoadWizard("NFSturn")
That did the trick.
Thanks for your help!!
