Mach Discussion => General Mach Discussion => Topic started by: mhdale on April 03, 2007, 05:38:21 PM
Hello all, I hope this post is in the appropriate place. I have been sifting through posts and the customize wiki to see if there is any relevant information for me, unfortunately I have had no luck. I was wondering if there is a built in OEM code for a LED which monitors an output above 6. There are outputs up to 20 or so but I cant find any information on a related LED for them. Basically I want to see if the Output is active or not I have a diagnostic screen showing all my inputs and outputs and the output buttons will toggle an output on and off, and the appropriate LED will light, but anything above 6 does not seem to have any OEM codes for them so my LED's stay sadly dark. Am I missing something? If anyone has the magic numbers for outputs 7 to 16 they would be appreciated!
Mike
There is a work around:
Put buttons on your diagnostic page that toggle on/off User Led's 7-20 that represent your Outputs you want to toggle.
Then in a Macro pump: (this scans at 10/sec)
If GetUserLED(1001) then
ActivateSignal(OUTPUT1)
End If
If GetUserLED(1002) then
ActivateSignal(OUTPUT2)
End If
Poppabear, Thanks for the post! I did something similar I created a button that toggled a User LED on the screen. I wanted to stay away from using the macropump. I am sure there is a reason those inputs are not as simple as 1-6 if anyone knows I would love to know as well out of curiosity.
I did a plugin a while back, under finished plugins, it maps User LEDs to all the Missing LEDs for the Outputs and inputs, comes with a modified OEM Mach3 screen set, the new LEDs are added to the Diagnostic page.
scott
