Third party software and hardware support forums. => PoKeys => Topic started by: FredMazak on November 24, 2014, 05:30:41 PM
Title: Mach3 v R3.043.066 & Pokey 55 software V2.1.15
Post by: FredMazak on November 24, 2014, 05:30:41 PM
Hi I bought a 2nd hand lathe Emco Turn 140 which is a 2 year ago retrofitted
with Mach3 (version R3.042.040) and an I / O board Pokey55 software Pokey 55
software V2.1.15
Perhaps the / transport (der) shaken loose some electrical wires (fixed
everything put back) and since then there are strange things with the MPG
which is controlled by the Pokey55 ..
Now I thought Mach3 to update to the latest version R3.043.066 >> but it
works with the old existing Pokey 55 software V2.1.15> if so should be
rewritten the scripts for the Toolchanger VB ???
Please your experience / advice
thx
Title: Re: Mach3 v R3.043.066 & Pokey 55 software V2.1.15
Post by: NeoTO on November 25, 2014, 02:00:25 PM
Based on the old version of the original Mach3, I assume that it was using the old plugin for Mach3 (written by Scott). Do you have any screenshots of the plugin settings?
Post by: FredMazak on November 26, 2014, 02:05:04 AM
Screen 1
Post by: FredMazak on November 26, 2014, 02:06:09 AM
screen 2
Post by: FredMazak on November 26, 2014, 02:07:44 AM
screen 3
Post by: FredMazak on November 26, 2014, 02:08:24 AM
screen 4
Post by: FredMazak on November 26, 2014, 02:14:51 AM
currently doing the MPG wheel again, but not its tool changer ...
grtz
Frederik
Post by: FredMazak on November 26, 2014, 02:28:16 AM
would a pokey 57E and PoKeyCNCaddon want to put in place of pokey55 since there are problems with the Pokey55 + I need additional inputs for safety proxy per axs
Can you help me with diagrams and script for MPG and toolchanger SAUTER Emco Turn 140
Here I would also Mach3 want to upgrade to the latest version
Thank you in advance
Kind regards
