Mach Discussion => General Mach Discussion => Topic started by: comet on April 02, 2007, 04:36:59 PM
could someone please explain the diferance between acpi and standard pc mode,
and how that relates to running mach3?
cheers
Tony
This is what I understand it to be
ACPI basically means windows shares IRQs for hardware and manages them when nesescary, usually this is ok but occasionally it can cause problems, it is I think dependant on motherboard design. Standard PC you can assign the IRQs manually.
Has anyone tried the REALTIME function available in Task Manager?? I stumbled across the function by right clicking on Mach3 in the Process Manager and a drop down appears where you can set the priority to Realtime. You also get a message indicating some bad things can happen. BUT, if this stops MS from interrupting Mach3 's functions during a prolonged run .........
JWI
Thats interesting the realtime thing,I just tried it and I'm sure I got a cleaner driver test.
prehaps you should post that as a question to get a better response.
Tony
Thanks Comet,
Any test you guys can do and report on would be great. That is what makes this forum so great. Lots of people sharing what they have learned. ;D
I AM A GAMER AND IF YOU DONT USE STANDARD PC DRIVER FOR PROC, INTERRUPTS
VIDEO CARD PIPELINE AND COMP, WONT RUN GAMES WORTH A DARN
