G-Code, CAD, and CAM => LazyCam (Beta) => Topic started by: houseboater1937 on April 02, 2007, 03:14:29 PM
I have just downloaded lazycam for the first time. I am not a teckie but I can still figure most things out. What I can't figure is how do you machine a face in milling leaving an island in the centre. The only thing I can do is profile and only if I only take one cut. If i want to take more than 1 cut do I have to put in extra lines around the profile.
Any help wopuld be appreciated
Doug
Hi, Houseboater:
If I read your questin correctly; There are two ways to leave an island. Easiest is if you have paid for the Pro-version of LazyCam. Then all you have to do is add an offset and key in different values for depth of cuts. If you want a lot of space between your outer perimeter and the island, you could then select the pocketing function.
The other way, and this is the way I have done it before LazyPro. is to draw your dxf with an offset and then select different chains. It is more difficult to leave a larger area using this metiod.
Hope I understood the question, and that this helps.
Bob @ BobsShop- Back to cutting and polsihing.
is lazy cam pro on sell now and is the turn portion working?
Turn has not been worked on but we hope to have time to work on it next week.
Thank you
Brian
