Third party software and hardware support forums. => Newfangled Mill Wizard => Topic started by: japrenticeuk on November 15, 2014, 11:07:07 AM
Ron - greetings
Running licensed 1.0.17 on Win 8.1 as Administrator.
Very frequently (5 times in 15 saves this afternoon) the program just drops dead with the "Windows trying to find a solution" dialog when trying to save G-code. The frame of the file picker is displayed but with no contents.
I cannot find the sequence to make it happen to order. I had a theory that the problem was a folder with a very large number of files but that does not seem to explain it as it then failed in a small folder.
Job file (which is meant to be a very simple demo for a prospective customer) is attached.
John Prentice
As you no doubt will guess I cannot make it fail. Since we converted to using the windows standards for file locations, and counting on the windows environment vars doing the right thing we have seen a few strange failures. I will keep poking at this one, hopefully I c an find the problem.
