Third party software and hardware support forums. => PoKeys => Topic started by: Weerasak on November 05, 2014, 11:16:56 PM
Title: Pokeys57E with LCD enable problem
Post by: Weerasak on November 05, 2014, 11:16:56 PM
I have problems where pulsing is not smoother, graphic on tool path window and  x, y, z DRO value run away from actual value.
It took me few days to track down this problem. I did change several things such as PC, Windows version, Pokeys setting before I spot problem when I disable LCD feature then the problem is gone.
I have designed a BOB for Pokeys, named PoBOB, which allows users to attache LCD on the bottom of BOB in case they want to attach it in the back of panel. I conducted several tests, including LCD. However during one test, I didn't realize having removed LCD  from Pokeys could cause mentioned problem.
Here is my prototype and introduction in Thai
http://www.youtube.com/v/aDQQaqN6FiA?hl=en_US&version=3&rel=0
I hope next version of Plugin will detect whether LCD attach or not. :D
