Mach Discussion => General Mach Discussion => Topic started by: Jimchi52 on November 03, 2014, 08:36:38 PM
Title: tool zero setup
Post by: Jimchi52 on November 03, 2014, 08:36:38 PM
I bought a zero tool setup pad and cannot get it to work correctly, anyone else have one?
Title: Re: tool zero setup
Post by: Tweakie.CNC on November 04, 2014, 10:55:54 AM
It would help if told us exactly which tool setup pad you have bought and how you are trying to set it up ??
Post by: Jimchi52 on November 09, 2014, 10:06:08 AM
Its a round pad with 2 wires, one goes to my breakout board and the other attached to the router bit. When I hit the button in mach it goes up but never comes back down
Post by: Tweakie.CNC on November 09, 2014, 10:18:50 AM
So it just a touch pad then.
What CB script do you have entered into your 'Auto Tool Zero' button ??
Post by: Jimchi52 on November 15, 2014, 04:28:41 PM
No script it didn't tell me to put any in
Post by: Tweakie.CNC on November 16, 2014, 01:19:37 AM
That's most likely to be your problem then.
Do a search for touch probe then choose one of the scripts posted which you think is best suited to your application.
Post by: Jimchi52 on November 19, 2014, 03:03:04 AM
Where do I search
Post by: Tweakie.CNC on November 19, 2014, 04:01:11 AM
Search box - top of main (Mach Forum) page.
If it's any help and to get you started you could use the scrip posted on my webpage here http://www.cooperman.talktalk.net/files/17.htm
