Mach Discussion => General Mach Discussion => Topic started by: mark4 on October 12, 2014, 10:19:44 PM
Hello
i am bidding on an upgrade for a bridgeport torq cut mill and am planning to use the csmio controller i have done several machines with this controller and have been very happy with it. now the base operation and wiring or rewiring i have a handle on and minor programing i do ok however i am worried about the tool changer. i have programmed a tool changer on a bostomatic successfully. the bostomatic tool changer i set up as an axis and wrote the code accordingly. my problem is the torq cut tool changer doesn't work as an axis it rotates by a cog and keeps track of where it is by a proximity sw i don't know how to program this type of system to rotate and keep track of where it is. this counts like an encoder but i am not sure how to translate that. so i am of two minds on the issue one is to program until i figure it out or two hire a programmer to write the tool changer program for me and warranty there work. to sum up i am asking for advise toward either of these options
thank you mark cook
hello
i forgot to add is there anybody out there that has already done a tool changer program on a bridgeport torq cut
thank you mark cook
Think JHChoppers may have done something similar, maybe worth giving him a shout or reading trough this post
http://www.machsupport.com/forum/index.php/topic,13365.0.html
thanks Hood
as usual you have opened my eyes i have been searching for a torq cut and didnt even think about the fact that the vmc's are very similar i have worked one. i have to read again but i like and can understand the way he set up the carousel will post the final.
Mark
Look forward to seeing the video ;)
