Third party software and hardware support forums. => Newfangled Solutions Mach3 Wizards => Topic started by: Keith on September 29, 2014, 04:47:51 PM
Title: Arc Wizard
Post by: Keith on September 29, 2014, 04:47:51 PM
Can anyone explain the arc wizard by Brian Barker to me. I've attached a .dxf file (and yes, I know I could use that to do the cut but since lazy cam freezes my machine...) and the arcs I want to make are in 'red'. If you could use these arcs and apply it to the qualities needed to be filled in on the arc wizard window, I think I can then make sense of it.
The cut is centered between two other arcs (in black) and I'll be using a .0625" mill end which will cut past those black arcs outside the red ones.
Thanks, Keith
Title: Re: Arc Wizard
Post by: RICH on September 29, 2014, 06:05:15 PM
Pic of arc geomertry. Play around with the wizard..........have fun.
