Mach Discussion => General Mach Discussion => Topic started by: Smackre on March 28, 2007, 09:24:34 AM
Why will my ignore tool change setting not stay disabled? ever time i load mach3 I half to disable it. Afew times I have forgotten and it got lucky and stoped it b4 it used the wrong tool.
Smackre,
When you say load Mach, are you just opening Mach, loading G-code into Mach, or downloading the latest Mach? Also, can you post a G-code file as an attachment that it is trying to do the tool change with?
Im talking about starting my comp up and opening mach3. Seems like evertime I exit mach3 and reload it i gotta redisable ignore tool change.
What version are you running? I'll do some test.
I am running verision 2.0
2.0.0??
Do me a favor, Open Mach, go to general config, Check ignor tool change, ok, close Mach. Open Mach back up and check to see if it has changed in general config. If it has changed, go through it again only this time, before you close Mach, go to operator, click on set normal condition. I have no idea if that will help as it doesn't seem to be an issue on mine. I'm running version 2.0.059.
It seems to be working now. I guess when I change a setting I should click normal conditions and then restart mach3.
Good, keep us posted.
Hi guys I have the same problem, I have tried oporator, then set normal condition, save and exit. Re open setting gone back to ignore tool change, even with no gcode ready. Still same. I want to set up with manual tool change position and touch plate set up, but want to sort out this issue first. Any ideas ?
I am having the same problem in version R3.043.066.
