Mach Discussion => General Mach Discussion => Topic started by: fishin_fl on September 17, 2014, 01:44:29 PM
I was wandering if anyone has used a Cmore touchscreen with mach3 cnc. I am trying to make a remote terminal on my table cnc to be able to move axis's, tool zero, laser on/off, vacuum table zones and ect. I really would like to use it if I can. I think it would be pretty cool if I could. I then could add a physical Estop. The part number is EA7-S6M. This screen does have a Serial PLC Port: RS-232/422/485 15-Pin D-sub (female) and ethernet. Here is the info on screen. http://www.automationdirect.com/static/specs/ea7s6mr.pdf
Thank you in advance if any one has any knowledge on this......
I can't answer your question on that particular screen, but if you are just looking for touch screen control here's what works for me. I built my own steel enclosure and fastened a Dell 2020 All-in-one with Capactiive touch, to the inside of the front panel. I used 3M automotive molding tape to fasten it. Works beautiful! Thanks, Brian
