Mach Discussion => General Mach Discussion => Topic started by: lew on March 27, 2007, 07:46:45 PM
Hi All:
I've now got a handle on using variables in a G code program. However, I'm still puzzled on how I can use a variable to represent a negative number.
Why does this not work?
#1=1.312 ;FIRST HALF CIRCLE RADIUS
#2=-#1 ;SECOND HALF CIRCLE RADIUS
G90
G0 X-1.5 Y0.0
M04
G0 Z-1.0
G01 X-1.312 F2
G2 X#1 Y0.0 R#1 F2
G2 X#2 Y0.0 R#1 F2
G0 Z0.0
M05
G0 X0.0 Y0.0
M30
When Mach reads #2 it gives an error something like "No digits found where real number should be".
I've tried it by giving #2 a value of -1.312 and it works fine.
Thanks in advance.
LEW
You have to do it like this
#2=-1.312 ;SECOND HALF CIRCLE RADIUS
Or if you only want to change 1 variable :
#1=1.5
#2=[#1-[#1*2]]
Graham.
Thank you Graham, You can tell I never use G code like that :)
Thank you, Brian and Graham for your replies.
Sorry for asking so many questions about variables. I come from an Ahha system which I still use and have "grown up" on. The Mach. system is somewhat different programming-wise. I need to get used to the differences.
Variables are one of the differences that I need to understand because I use them in quite a few programs. I've found that it simplifies things for future use when I desire to make changes. Actually, I've become comfortable writing code for the Ahha using variables and have a few "canned" programs for drilling and simple pocket routines where all I have to do is change a few variables at the beginning of the program and I can start cutting chips quickly.
Just trying to get to this level with Mach.
I have found one thing of interest that seems awkward with the Mach system. Perhaps you can shed some light. In Ahha a circle could be coded on one line using x,y,i,j. In Mach. if I understand it correclty, a circle has to be programmed as two semi circles. Any reason for this?
I guess you can see where the variables would come in handy.
By the way, Graham, I appreciate your example on how to use one variable and have it change the negative side as well. I'll be using that right along.
LEW
Just a side note:
I have found that this will work also -
#1=1.5
#2=[0-#1]
Found that out right after posting the previous message.
Out for now.
LEW
LEW,
You can do IJK circles but if you do R's you must do them in no more then 180 sections
Hope that helps
Brian
