Mach Discussion => General Mach Discussion => Topic started by: iCacic on August 25, 2014, 02:34:51 PM
Hello,
I have servo drivers who gives High signal on servo failure.
I have added that signal as input1 in Mach3.
Now I don't know how to configure Mach3 to go to estop when input High,
and maybe to display "servo failure". Just maybe.
Any help would be nice.
Thanks, Ivan
There is a check box on General Config page to make Mach sop on Input1 signal.
To do the message part you could use a Brain or the macropump to inform you.
Personally I would use the macropump and have it also E-Stop Mach when Input 1 is seen.
