Mach Discussion => General Mach Discussion => Topic started by: stephanbrunker on August 18, 2014, 05:42:48 AM
Because mentionend in the Turn Handbook, i tried the G77 / G78 canned cycles. But in G77 I found two bugs.
Line 48-52 must be:
If( Taper = 0 ) Then
ZCalc = Abs(StartZ - EndZ) 'was ZCalc = 0, which ignores EndZ further on
Else
ZCalc = Abs(StartX - EndX) /Tan((Taper * PI)/180)
End if
and Line 71-74 must be:
If IDOD =1 And PassDia <= EndX Or IDOD =-1 And PassDia >= EndX Then 'was < and > instead of <= >=, which causes to repeat the final cut
PassDia = EndX
LoopExit = 1
End If
seems that nobody has used these two since creation (2009).
Seems that they were some other bugs in that macro too. I'm going to rewrite it with a roughing and a sizing stage - like in the wizard. But the OD Turning wizard has also a kind of bug inside. If you've a tool with an angle of around 80°, then you'll produce a nice crash in the sizing stage. Because after the last turning, it continues the z axis move to Z End and removes all the material at once because it takes the turn from inside out - it has to be the other way.
I've solved my problems by rewriting the M1077 and M1078 macros. I use them quite often, because it's the simplest way to machine standard parts on the lathe - by combining G77 / G78 words. It first does roughing with the values in the general options when no h word is given and makes a sizing move with 40% feed and 40% of the roughing amount. Also, it evens the roughing passes out so that they are all the same amount. So, here is my code, without warranty of course:
M0177:
' G77
'(Xx.*********x XDia NEEDED)
'(Zx.*********x End Z NEEDED)
'(Fx.*********x Feedrate)
'(can be Set In the settings page: 'Hx.*********x Depth of cut)
'(Cx.*********x Clearance In the X)
'(Qx.*********x Clearance In the Z)
'(Kx.*********x ZStartpoint)
'(Rx.*********x XStartpoint)
'(Tx.*********x Taper In Deg)
Sub Main()
ZClearance = Abs(tZClear()) 'This one it not avalable
XClearance = Abs(tClearX())
StartX = tXStart()
StartZ = tZStart()
EndX = tEndX()
EndZ = tEndZ()
Taper = tTaper()
FirstPassDepth = tFirstPass()
RoughAmount = abs(tCutDepth())
Feed = Feedrate()
SizingAmount = RoughAmount * 0.4
SizeFeed = Feed * 0.4
PI = 3.1415926
If StartZ > EndZ Then
RightLeft = 1
Else
RightLeft = -1
ZClearance = ZClearance * -1
End If
If StartX < EndX Then 'Inside Turning
IDOD = -1
XClearance = XClearance * -1
Else
IDOD = 1 'Outside
End If
'Calc the distance X needed to make the taper angle
TaperX = Abs(StartZ - EndZ)* Tan((Taper * PI)/180)
If TaperX > Abs(StartX - EndX) Then
EndZ = StartZ - Abs(StartZ - EndZ) * RightLeft * ( Abs(StartX-EndX) / TaperX )
TaperX = Abs(StartX - EndX)
End If
code "G0 X" & StartX + XClearance & " Z" & StartZ + ZClearance
code "F" & Feed
PassNum = 1
LastPassDia = StartX
'optimize roughing value
Passes = (Abs(StartX - EndX) - SizingAmount) / RoughAmount
If CInt(Passes) <> Passes Then
passes = CInt(Passes) + 1
RoughAmount = (Abs(StartX - EndX) - SizingAmount) / Passes
End If
Do 'Roughing Loop
PassDia = StartX - (RoughAmount * IDOD * PassNum)
code "G0 X" & PassDia
If TaperX <> 0 And Abs(PassDia-EndX) < TaperX + SizingAmount Then
'Taper turn section
ZCalc = StartZ - RightLeft * Abs(( (StartZ - EndZ) * (Abs(PassDia - EndX) - SizingAmount)) / TaperX )
code "G1 Z" & nFmt(ZCalc,4)
If (Abs(PassDia-EndX) < TaperX + SizingAmount) And (Abs(LastPassDia-EndX) > TaperX + SizingAmount) Then
code "X" & EndX + (TaperX + SizingAmount) * IDOD & " Z" & EndZ + SizingAmount * RightLeft
code "X" & LastPassDia
PosZ = EndZ + SizingAmount * RightLeft
Else
ZCalc = StartZ - RightLeft * Abs(( (StartZ - EndZ) * (Abs(LastPassDia - EndX) - SizingAmount)) / TaperX )
code "X" & LastPassDia & " Z" & nFmt(ZCalc,4)
PosZ = nFmt(ZCalc,4)
End If
If PassNum = Passes Then Exit Do
code "G0 X" & LastPassDia + XClearance & " Z" & PosZ + ZClearance
Else
'Straight turn section
code "G1 Z" & EndZ + SizingAmount * RightLeft
If Abs(LastPassDia - PassDia) < Abs(XClearance) Then
code "G0 X" & PassDia + XClearance & " Z" & PosZ + ZClearance
End If
End If
code "G0 Z" & StartZ + ZClearance
LastPassDia = PassDia
PassNum = PassNum + 1
Loop
'sizing
code "F" & SizeFeed
If Abs(EndX - StartX) > TaperX Then
If TaperX = 0 Then
End If
code "X" & StartX + XClearance
code "Z" & EndZ
If TaperX <> 0 Then
code "G1 X" & EndX + (TaperX + SizingAmount) * IDOD
code "G0 X" & EndX + XClearance + (TaperX + SizingAmount) * IDOD & " Z" & EndZ + ZClearance
Else
code "G1 X" & PassDia
code "G0 X" & PassDia + XClearance & " Z" & EndZ + ZClearance
End If
End If
code "Z" & StartZ + ZClearance
code "X" & EndX
If TaperX = 0 Then
code "G1 Z" & EndZ
code "X" & PassDia
Else
code "G1 Z" & StartZ
If Abs(StartX-EndX) > TaperX Then
code "G1 Z" & EndZ & " X" & EndX + TaperX * IDOD
code "G0 X" & EndX + (TaperX + SizingAmount) * IDOD + XClearance & " Z" & EndZ + ZClearance
code "X" & StartX + XClearance & " Z" & EndZ + ZClearance
Else
code "G0 X" & StartX + XClearance & " Z" & EndZ + ZClearance
End If
End If
code "G0 X" & StartX & " Z" & StartZ
code "F" & Feed
End Sub
Main
M0178:
'G78
Sub Main()
StartX = tXStart()
StartZ = tZStart()
EndX = tEndX()
EndZ = tEndZ()
Taper = tTaper()
RoughAmount = tCutDepth()
Feed = FeedRate()
PI = 3.1415926
IDOD = -1
Else
IDOD = 1
End If
RightLeft = 1
Else
RightLeft = -1
End If
If Taper <> 0 Then
TaperZ = Abs(StartX - EndX) / Tan((Taper * PI)/180)
If TaperZ < Abs(StartZ - EndZ) Then
EndZ = StartZ - TaperZ * RightLeft
Else
TaperX = Abs(StartZ - EndZ) * Tan((Taper * PI)/180)
End If
End If
code "F" & Feed
PassNum = 1
LastPassDepth = StartZ
Passes = (Abs(StartZ - EndZ) - SizingAmount) / RoughAmount
Passes = CInt(Passes) + 1
RoughAmount = (Abs(StartZ - EndZ) - SizingAmount) / Passes
End If
Do
PassDepth = StartZ - (RoughAmount * PassNum * RightLeft)
code "G0 Z" & PassDepth
If taper <> 0 Then
XCalc = EndX + IDOD * Abs((StartX - EndX) * (Abs(StartZ - PassDepth) + SizingAmount) / TaperZ )
code "G01 X" & XCalc
XCalc = EndX + IDOD * Abs((StartX - EndX) * (Abs(StartZ - LastPassDepth) + SizingAmount) / TaperZ )
code "X" & XCalc & " Z" & LastPassDepth
PosX = XCalc
code "G0 X" & PosX + XClearance & " Z" & LastPassDepth + ZClearance
Else
code "G1 X" & EndX + SizingAmount * IDOD
PosX = EndX + SizingAmount * IDOD
code "G1 Z" & LastPassDepth
If Abs(LastPassDepth - PassDepth) < Abs(ZClearance) Then
code "G0 X" & PosX + XClearance & " Z" & PassDepth + ZClearance
End If
End If
LastPassDepth = PassDepth
Loop
'sizing
code "F" & SizeFeed
If Taper = 0 Then
code "G0 X" & EndX + SizingAmount * IDOD + XClearance & " Z" & EndZ + SizingAmount * RightLeft + ZClearance
code "X" & EndX
code "G0 X" & EndX + XClearance & " Z" & EndZ + SizingAmount * RightLeft + ZClearance
Else
code "G0 X" & PosX + XClearance & " Z" & EndZ + SizingAmount * RightLeft + ZClearance
End If
code "Z" & EndZ
code "G1 X" & StartX
If taper = 0 Then
code "X" & EndX
code "Z" & EndZ + SizingAmount * RightLeft
code "G0 X" & EndX + XClearance & " Z" & EndZ + ZClearance
Else
If Abs(StartX - EndX) > TaperX Then
code "X" & EndX + IDOD * TaperX
End If
code "X" & EndX & " Z" & StartZ
code "G0 X" & EndX + XClearance & " Z" & StartZ + ZClearance
End If
code "F" & Feed
End Sub
Main
If you use the Tooltable, then these macros have an additional error: The "T" word initiates a tool change and/or the taper. So, you have to rewrite them with a variable for the taper.
Just a quick note to say thanks for taking the time to document this. I'm not far enough along in my CNC lathe odyssey to fully understand what you're talking about but enough so that I feel a little less responsible for some of the unexplained crashes I've had. Keep up the good work! ;D
Solving the taper issue is easy - i forgot to post it here:
in the macro, you should edit the line
taper = tTaper()
to
Taper = GetVar(101)
SetVar(101,0)
If Taper > 90 or Taper < 0 Then
message "Error, Taper out of Bounds"
code "M30"
Exit Sub
End If
so it takes the taper angle from a user variable and resets it after use. in the GCode, program prior to your macro call #101=45 , if you want something different than zero.
Because I don't want to update the code at two locations here the link to my personal page with the last version of the macros:
http://www.stephan-brunker.de/Maschinen/Software/body_software.html#M1077 (http://www.stephan-brunker.de/Maschinen/Software/body_software.html#M1077)
stephanbrunker,
Never used the lathe macros for G77 and G78 in all these years. :D
Thanks for pointing out the bugs and fixes.
Much appreciated......keep up the good work,
