Mach Discussion => General Mach Discussion => Topic started by: mlucius on August 14, 2014, 07:23:28 PM
Hi there. A simply newby question: Is it possible to interrup the GCdde vel constant movement of an axis by an external signal and then continue the movement with a constant desaceleration.
Thanks in advanced.
Of just a single axis? Or all? And why?
Btw, I would think yes as to changing it for all axis simultaneously. Not sure of the ability with a single axis.
For all axis. It is a pick & place machine resolved by CNC: MACH3, AKZ250, Delta Servo drivers & motor.
>And why?
I need to change the movement in answer to a proximity sensor signal mounted in the hand.
Have your sensor call the feedhold button.
