Mach Discussion => General Mach Discussion => Topic started by: Lmecano on August 12, 2014, 03:36:02 PM
Title: Motor whistling only with Mach3
Post by: Lmecano on August 12, 2014, 03:36:02 PM
Hello,
I have just built my home-made CNC and I have a set-up problem, I guess.
When I'm using my CNC with my manual interface, no noise. However, when I launch Mach 3 - it means I desactive the Reset button - my stepper motors make a strange noise. Even if that noise don't impede my stepper motor to work, it's quite... annoying.
Do you have any ideas where the problem could be ?
Thank you for your time !
Title: Re: Motor whistling only with Mach3
Post by: Lmecano on August 14, 2014, 10:46:54 AM
I have read the Mach3 documentation and... nothing.
Maybe a video could help to describe the problem,
https://www.youtube.com/watch?v=qWu4QUgrB1Y (https://www.youtube.com/watch?v=qWu4QUgrB1Y)
Post by: Kenneth on August 14, 2014, 12:01:41 PM
try retuning the motors.
hope this helps !
Post by: Lmecano on August 14, 2014, 02:09:28 PM
hope this helps !
Do you mean try to modify stepper motor wiring ?!
Post by: ger21 on August 14, 2014, 03:23:55 PM
What drives are you using. Some drives are just noisy, and there's nothing you can do about it.
Post by: Hood on August 15, 2014, 06:05:45 PM
Seem to recall that some, if  not all, of the TB type boards use full step when in external mode and that makes them quiet but when under Mach control the microstepping, set on the boards, comes into play and that can cause noise.
Could be totally wrong, often am ;)
Post by: Kenneth on August 21, 2014, 06:13:03 AM
under Config/Motor Tuning you're able to adjust the velocity and acceleration.
i had some noise and that helped me.
good luck !
hope this helps !
