Mach Discussion => General Mach Discussion => Topic started by: Sunderz on July 22, 2014, 10:06:00 AM
Hi guys, sorry if this is the wrong section could'nt see an xp based problems section.
I have been running mach 3 under xp and after working 2 hours through a 4/5 hour rough cut an error appeared on the screen. Art Code: 9991...now I am leaving the machine running to complete the path but can any one shed light on what this means and what has caused it...
thanks in advance
chris.
Are you using any plugins?
If not change the name of the plugin folder to something like OldPlugins then create a new, empty, folder called Plugins.
Hopefully that may help.
