Mach Discussion => General Mach Discussion => Topic started by: Matej on July 01, 2014, 05:51:01 AM
Title: 4 Axis foam cutter problems with set up
Post by: Matej on July 01, 2014, 05:51:01 AM
Grettings all,
I'm a newbie at this and I have quite a few problems setting it all up.
Little background information, machine was bought from a person who made it himself or so he says. Electronics looks like it was made by him (judging by names and marks on circuit) so I don't really know which pin goes where on printer port.
So first thing, foamworks works normally, I can move single axis are both X / Y or all.
So normally I tried copying pins into mach 3 and I couldnt move anything, I was trying to figure out output pins and enable.
From foamworks I know this:
X1 direction pin 2
X1 step pin 3
X2 direction pin 6
X2 step pin 7
y1 direction pin 4
y1 step pin 5
y2 direction pin 8
y2 step pin 9
I setted enable and output pins same as step pin and was only working on getting X axis to move.
I got it to move X (but it's not working anymore) so I could move X and X2 (slave A). But it could only move once. Meaning if I pressed tab in mach and move axis X (button jog) it would move and it would keep moving until button was pressed.
Then if I try to move it again (again button press) it won't move until I open Parallel Port Monitor and click on pins so everything is green (low?) except pins 10-13, 15 which cannot be changed (input pins?).
So question here is how can I set it up so mach will return the pins to previous state?
After that I tried to move Y axis same as X even though I knew it could only be moved once. But as soon as I enabled Y and Y2 (slave B)
I couldnt move anything, not X or Y, so I disabled Y again and I still couldnt move X although it was same as before.
So now after pulling my hair out and googling for good 4 days I ran out of ideas.
Now only thing that works is this:
I click on jog button to move anything, motor spins for 1 second and stops. Wont move anything again until I click on pins on Port Monitor.
steps for motor is 157, kernel speed is 25k, computer running XP SP2, 1Gb ram 3,4Ghz CPU
I would appreciate all the help I can get.
