Mach Discussion => General Mach Discussion => Topic started by: cncrailroad on June 20, 2014, 11:12:54 PM
Title: Needing Help!
Post by: cncrailroad on June 20, 2014, 11:12:54 PM
I just finished building a new CNC Router and have everything running on Mach 3 with no problems. I'm looking to add a plug-in device to my machine so that I can control movement in all directions in .001 increments for final set-ups.
What are people using to accomplish this task?  Any suggestions would be greatly appreicated.
Chuck
Title: Re: Needing Help!
Post by: ger21 on June 21, 2014, 06:08:36 AM
You can set your jog increment to .001 and use the keyboard?
Post by: cncrailroad on June 21, 2014, 10:16:36 PM
OK so how do I do that? Not trying to be smart just don't know how to do that.
Is there an instruction booklet I can get or down load?  What do you think of the Shuttle Pro device?
Thanks Chuck
Post by: ger21 on June 22, 2014, 06:32:01 AM
Never used the shuttle Pro.
Hit the TAB key on the keyboard, and you can change to jog step mode and choose the increment.
Post by: cncrailroad on June 23, 2014, 03:58:48 PM
 :) Thanks Gerry.
Chuck
Post by: garyhlucas on June 23, 2014, 07:26:04 PM
Something I learned from breaking stuff.  I like to use a large round pin for picking up the top of a part or even edges.  By using a large pin the tool is always far enough away that an oops like a jog in the wrong direction won't crash the tool into the part ruining your whole day.  On top I roll it back and forth quickly under the tool until it touches. On the side is a little trickier but no big deal.  It's like sailing a boat.  It not the water that gets you in trouble, it is the hard parts around the edges!
