Mach Discussion => Mach3 under Vista => Topic started by: babli on May 13, 2014, 01:41:27 AM
Title: tangent knief control with online Z value
Post by: babli on May 13, 2014, 01:41:27 AM
Hello, i need to use the Tengnetial kneif on 4th axes, but to change the depth online need Z axes to work online, i mean while in process the Z axes value need to be increased or decreased. one more trouble, when i run a G code, the Z axes & A axes work together in rapid movement, i need first to move Z axes in + value & then A axes while in rapid, is it possible, can i get help for this?
