Mach Discussion => Mach4 General Discussion => Topic started by: Overloaded on May 09, 2014, 07:40:00 AM
Title: ? about MachPlc.mcs file in Mach4Mill folder ?
Post by: Overloaded on May 09, 2014, 07:40:00 AM
What is this for and is it used or seen by the sw ?
Looks like a template ? Write your script here to test, debug then save somewhere else ?
Reason I ask, I had some script in there and saved then closed. Then M4 would not start up, just blank screen "not responding".
Just curious.
Russ
Title: Re: ? about MachPlc.mcs file in Mach4Mill folder ?
Post by: Brian Barker on May 10, 2014, 05:27:20 PM
That PLC script is for the wxMach.exe Static GUI. So if you stay in MachGUI.exe it will not that PLC code.
Brian
