Mach Discussion => General Mach Discussion => Topic started by: Learn on April 26, 2014, 01:55:53 PM
Title: computer crashed need HELP!!! transfering data
Post by: Learn on April 26, 2014, 01:55:53 PM
Ok I will try to make this short . I purchased a machine from someone and I got the machine home with everything intact. I turned the computer on a couple of times and then the last time I tried it the computer would not get past the starting page . Prior to this it was working  to my knowledge with out any issues . so I try to load everything in and it would not start up. I went to the old owners shop and he looked at the hard drive and he said it was fine . He then backed up my Mach 3 files o a USB jus in case. Now I have another computer ready to use and have loaded te Mach 3 info into the "C" drive. now I power u he machine and it will not ove the machine at all. Is there  something that Iam missing ? I have had this machine for a week now and have been unable to get the darn thing to run.  now I would use the old Hard drive I n the new computer but the wire set up is way different.
So how do I load al of my parameters in to the new computer so it will work ?
soe one please help before I loose my mind . This is killing me . I don't know what else to do
Title: Re: computer crashed need HELP!!! transfering data
Post by: Fastest1 on April 26, 2014, 05:08:23 PM
Mach doesnt open or it doesnt create movement?
Post by: Learn on April 26, 2014, 07:08:58 PM
It does not make movement . Also I have an error now on my phase converter
Post by: Fastest1 on April 27, 2014, 08:53:09 AM
Do you get power for your PC thru 1 of the legs off of the convertor?
Is your copy of Mach licensed (it should work anyway if set up correctly)?
Did you install the last working xml?
Post by: Learn on April 27, 2014, 09:34:31 AM
As far as I am aware it is  licensed to the guy I bought it from. He no longer uses it . XML ? where do I find that?
as far as power  I am not sure . I am def not a computer guy just a cnc programmer
Post by: Learn on April 27, 2014, 09:35:25 AM
The converter gets power from the 220 on the wall and then a few wires are connected from the controller .
Post by: Fastest1 on April 27, 2014, 06:25:37 PM
An XML is the profile. It had all of the ports and pins settings contained within.
Post by: ger21 on April 27, 2014, 08:24:52 PM
If you copy the entire mach3 folder from the old PC to the new one, it should run the same on the new one. The .xml file with the settings should be in the Mach3 folder.
Post by: Learn on April 28, 2014, 03:48:19 AM
Ok I have both the new. Computer and the old hard drive hooked up and both are set up with the mach 3 . I bought the external box for the hard drive just in case . Now I'm thinking I may need to return that box.   good news is I have been in contact with the original owner who. Built this thing and we arranged for him to come over today and help get this thing going. Now the only thing I can think of is maybe one if the wires that goes from the cnc controller board to the vdf is not hooked up properly and is faulting it out. When I transported the machine to my house we had to disconnect the wires in order for us to transport it. Looking at the set up their are some dated connectors and almost all of the wires are just ran like spaghetti with no real protection. So I ordered some correlated wire cover to ad protection . I will update all of you as soon as I can . Thanks so far for the replies .
Post by: Fastest1 on April 28, 2014, 06:45:36 PM
The original owners will understand the requirements and have you up and running in minutes. It isn't hard after you are familiar with it. That being said, next week I will be posting a total Noob question.
Post by: Learn on April 29, 2014, 03:45:56 AM
Ok after talking to the original owner we realized that it may just be a port issue . I went into the config /port pin section and it appears to be correct . . The machine will not jog around still. I'm going to run a new wire from the vdf to the cnc controller as I see that is causing the error on the vdf. That might be the culprit. Original owner rescheduled to see it Wednesday.
Post by: Learn on April 29, 2014, 03:50:35 AM
The wire is for the logics that will be replaced
Post by: Learn on May 01, 2014, 11:35:56 AM
well the owner had an unexpected thing pop up and said he may be able to come by today.
I am thinking I need to replace the logics wire that runs from the control to the phase converter. does anyone know what wire I should be using ?
Post by: Learn on May 02, 2014, 03:43:08 AM
Problem solved!! The original owner came by last night and we tested things for a couple hours  and had to install the software . And run a couple of new wires .!!!!!  ;D now time to wrap things up so I can start cutting .  Thanks for all the replies
Post by: Fastest1 on May 03, 2014, 08:16:22 AM
Great to hear the machine is up and running.
Post by: Learn on May 17, 2014, 07:07:31 AM
we have it up and running now !!! I put all file in my c drive but never installed the drivers   what was I thinking ??? LOL
