Mach Discussion => General Mach Discussion => Topic started by: BlrUsr on March 14, 2007, 08:59:48 AM
Please tell me why in "config->port and pins -> Encoder/MPG's" exist ENCODER4 , but in settings I can't see Encoder Position 4-th coord?
I know that xencoder - that oemcode 29 , z-31, but A-?
Are you looking for the OEMcode for the 4th axis?
Yes if this exist
Use Number 100 - 103 for ABC axis
Thanks a lot
I add oem 100 - all ok, but while I rotate encoder - it's increment or decement without limitation at 360
I use à rotate A-axis, which I want to drive manual and monitor it on mach.
I use 1024-pulse encoder and 1.degree = 1024/360 = 2.844444... pulses and 1pulse=0.3515625 degree (doesn't metter)
I have Index signal on encoder, maybe I can use it? Such as "home" for A-axis
There is no homing to an encoder index at this time :( also we have never put in code to reset the count every 360... It is something that could be added but I think that will have to wait for quantum as we are trying to lock down Mach3 at this time.
Brian
