Mach Discussion => General Mach Discussion => Topic started by: jhb_in_seattle on March 13, 2007, 03:28:51 PM
Hello,
I've been a long distance admirer of lathes and milling equipment. With the birth of my daughter, I find addressing those old desires again.
With that motivation, I started looking at some low cost options in the construction of a 3-axis CNC milling machine. I have only 3 questions, for now, to ask.
I've noticed that there are many free CAD and CAM options. My concern is with conductivity. Do all CAD programs provide a standard file type that all CAMs can use?
Do all CAM programs communicate through the NMC protocol?
G-Code is generated by the CAM process and that is sent to the motor drivers?
Any help would be greatly appreciated.
All CAM programs store files in there own format, but most will import/export the standard file types e.g. iges, dxf.
The g-code generated must be formatted to the requirement of the controller (Mach) this is done by the post processor within the CAM software.
The g-code is then loaded into Mach and Mach converts the code into step/direction pulses and on/off signals.
Graham.
