Mach Discussion => General Mach Discussion => Topic started by: connors934 on March 13, 2007, 01:52:27 PM
Hi all
Here's what I have:
Taig Micromill, a couple of years old, just upgraded to mach 3, xp computer, pentium III, 40 g hard drive, mostly empty
the motors are not responding to the keyboard jog.
Printer port is 0x378
The pinouts are set to
axis | step pin | dir pin | dir lowactive | step lowactive | step port | dir port
x 3 2 active low active low 1 1
y 5 4 active low active low 1 1
z 7 6 active low active low 1 1
Neither sherline mode or non works.
No motor response, except they twitch when I turn the computer on.
any suggestions?
Chris
Here is where I got the info for the pin outs
http://www.cartertools.com/mill.html
Chris
You also should try Sherline mode... ther drivers for the Taigs are a bit slow
Here are photos of the inside of the controller
One of the circuit boards says 2003
http://flickr.com/photos/connors934/423219757/
http://flickr.com/photos/connors934/423219639/
If this is not compatible with mach3, will it run with an older version, mach 2 or 1?
thanks a bunch
Chris
do you have the pinout for the drive?
These are the pinouts I am using, info is from Nick Carter - http://www.cartertools.com/mill.html
Chris
My step pins are even and dir pins are odd.
Robert
That would be a problem ;)
The motor tuning settings that seem to work best are:
- all axes (except 4th, which has different value needs)
Step 32000 Vol 9.654 Accel 2.25 Pulse 0 Dir 0
- jog rate % 25 (it was set by default at 95%)
This allows it to jog from the keyboard, but it doesn't run code properly.
The scale is off x y and z and the speed is faster than the steppers can handle when it runs a file.
Chris
You need to set your Max velocity to about 25% of what it is now. You do this under your motor tuning. If you can't run at 100% jog you will not be able to run a G00 (Rapid) move.
