Mach Discussion => General Mach Discussion => Topic started by: Quin on April 02, 2014, 08:32:41 PM
Just converted from V1.84 to V3.043.057.
I build a screen and save it as 1280 x 1024. When I open Mach3 with a 1024 x 768 resolution, I don't get the full screen. when I increase the resolution, it only fills 75% of the screen and displays my hidden buttons and DRO's.
I am using windows XP.
Suggestions?
Quin
If you have DRO's and Buttons that are off the main screen area, then you need to design your screen to the exact resolution of your monitor, and turn off auto screen enlarge.
The hidden objects need to be outside of the range of the monitors resolution.
Hi Gerry,
Turning off the "auto screen enlarge" solved the problem.
Quin
