Mach Discussion => General Mach Discussion => Topic started by: Davek0974 on April 02, 2014, 04:07:56 AM
I have a "Origin" button on my plasma screen, it sets all the work DRO's to zero from my pendant.
Is there a way to have this button also press the "Regen Toolpath" button after it does its reset??
This would stop getting soft limit errors when using the pendant to start a job.
- edit button script from mach via menu, or modify screenset with machscreen app
- regen toolpath with:
DoOEMButton(160)
at the end of the button script (160 is OEM button code of regen toolpath button)
- if you need to wait for machine to stop moving, put this before regen toolpath:
while isMoving()
sleep(100)
wend
I haven't tested it, but that should be the concept. There is lot of useful info in
http://www.machsupport.com/wp-content/uploads/2013/02/Mach3_V3.x_Macro_Prog_Ref.pdf (http://www.machsupport.com/wp-content/uploads/2013/02/Mach3_V3.x_Macro_Prog_Ref.pdf)
if you're interested.
Brilliant i will give it a go later on.
Hmm, if I try to edit button script, the only buttons that flash are "ref all home" and "display mode", I can't edit the "Origin" button, Is there another easy way in??
Probably there's no script attached to that button, and the button just executes one preprogramed function.
Check
http://www.kd-dietz.com/klausphp/pages/eng/machscreen/description/ms_description.html
Make backup of your mach instalation, and open screenset file with machscreen. When you select "origin" button, properties edit window will be populated with button properties. Note which function code it executes, then edit the script and execute same function via script, then add your custom code after that. Again that's the concept, but if your pendant is executing mach function, rather then emulating button press, it will not work. In that case, you'll have to find out how mach interprets pendant signals, and change the behavior(mach response) there - sorry, I know nothing about pendants.
Good luck
Well I've downloaded and got machscreen running but its way over my head i think.
All i could gather was the the Origin button has a short-cut of Ctrl-O, calls function 1007 and that's about it.
Is there a way I can add this simple command ?
1007 is the OEM code for "ZeroAll", if you open the screenset in the screen designer then you can double click the button and change it to a VB button. When you then open in Mach it will be a VB button and you can add the code you wish.
Any idea how i do that. I'm not seeing any "convert to VB" features mentioned????
...or click exec code in property editor (in second column), click basic script, and put your code there:
DoOEMButton(1007)
DoOEMButton(160)
I dont use MachScreen so not sure how you do it there, in Screen4 the option is there.
As mbele has pointed out you could use the Code function to do it as long as it allows multiple line code.
Hmm, getting in a mess now (got backup copy though)
I have added the codes dooembutton(1007) zero all
and dooembutton(160) regen toolppath
but now it zeros the dro's then regens the path but then sends the dro's back to somewhere else leaving them non-zero?
It puts the DRO values back to exactly where they were before pressing the button.
i.e. its not storing them.
You really want a pause between calls
Sleep 500
would give you 1/2 second delay between calls.
BTW are you doing it via code in the screen designer?
If so are you able to do multiple lines? If not then likely that is your issue, doing it in a VB button would be best.
I will add the sleep command
Once I added the script in machscreen, it saved a custom macro, I can now edit that macro with notepad :)
Machscreen is a very "odd" program ;)
That fixed it, it seems that although it creates a macro file it does not use it but instead embeds the code?
Anyway its working nicely now
Thanks all
You're right, I've tested it, and it seems that it behaves weird. Anyhow, here's the script that works for me:
SetOEMDRO(800,0)
SetOEMDRO(801,0)
SetOEMDRO(802,0)
It will automaticaly regenerate toolpath.
I think that when DROs are defined as "standard" (codes 0,1,2) path will not be regenerated by default.
(jog follow must be turned on, i think)
That's good, at least two ways of doing it then :)
