Mach Discussion => General Mach Discussion => Topic started by: comet on March 12, 2007, 12:49:45 PM
Title: Retrofit Bocsh cc100
Post by: comet on March 12, 2007, 12:49:45 PM
   hope someone can help!
Is it possible to retrofit a router which is controlled with a Bosch cc100,with mach3
  The router is a 1986 wadkin UX type.
I believe it is equipped with perm mag servo motors.
  Any help/info would be much appreciated.
   Tony
Title: Re: Retrofit Bocsh cc100
Post by: Brian Barker on March 12, 2007, 10:41:37 PM
You are going to need the specs off the motors and once you have that you can look at servo drives. Look at the drives from CNC Teknix drives (I think they will be about the right size also see if you can use GeckoDrives)
