Mach Discussion => Mach Screens => Topic started by: BOHICAMAN on March 19, 2014, 09:47:25 PM
I've looked around, but can't find any info- or a way- to put the BACKGROUNDJOG Pendant on the Left side of the Mach3 screen. I'd like to not cover the toolpath screen with it. As always, any assistance is greatly welcomed!
Bob
I believe that this is hard coded and cannot be changed.
That's what I'm starting to think! On the other hand, if I'm making a new page and putting that "picture" on it, I don't see why it is any different than building the other pages.
Hey Bob, if you just TAB the pendant for a brief period, you could just add the toolpath window to that page.
You can then hit TAB, drag the edge all the way to the left, hit TAB again to close it NOW, you have to hit tab again and drag once more, then , from then on it will always open the pendant where you want. Just need to do it 2 times for some strange reason.
This is what it would look like.
You could add whatever else you might want.
Russ
Russ,
Thanks! I'll give it a try tonight as I'm headed out right now. I appreciate the help!
Bob
Page 50 is a special page, and always opens and closes from the right side. There's no way to change it.
Ok, thanks!
Bob
