Mach Discussion => General Mach Discussion => Topic started by: signweld on March 17, 2014, 06:32:00 PM
Title: Mill works normally, but plasma acts odd.
Post by: signweld on March 17, 2014, 06:32:00 PM
I am up and running Mach3.  I open the "Mach3 loader icon on my desktop, choose Mach mill, it loads up and all is well. runs as it should be.
  If I Choose Mach plasma, it opens  up. I have it configured the same settings as in "mill" version but jog does'nt work correctly. The Y axis is reversed direction and runs slow. When I press the cursor key to move in the X axis the Z goes up and down. Pressing pg up or down to move z, nothing happens. Now I'm totally confused. Im sure I missed a setting correctly, Have been puzzled for a week, and run out of ides of what to search the forum topics for.
Paul M.
Title: Re: Mill works normally, but plasma acts odd.
Post by: Tweakie.CNC on March 18, 2014, 03:38:21 AM
Hi Paul,
For your Plasma, it sounds to me like you have your Step and Direction pins set incorrectly in Config / Ports & Pins / Motor Outputs (also check that your Active Hi's / Low's are configured correctly).
Post by: signweld on March 18, 2014, 09:03:21 AM
Thanks for the quick reply. I double checked the settings in both this morning and the problem still exists.  This is a properly licensed Mach3 ver R.3.043.066.  My Config / Ports & Pins /Motor / Output settings are:
                                               X - G - 2 - 3 - R - G - 1 - 1
                                               Y - G - 4 - 5 - G - 1 - 1- 1
                                               Z - G - 6 - 7 - G - G - 1 - 1
While it moves incorrectly, the DRO's read correct
Paul M.
Post by: stirling on March 18, 2014, 09:47:11 AM
please post both xml files - mill and plasma
Post by: signweld on March 18, 2014, 12:14:17 PM
Attached are the XML files.
Paul M
Post by: signweld on March 18, 2014, 12:22:08 PM
  And here is the mill XML. I keep getting the message"Sorry! There is already an attachment with the same filename as the one you tried to upload. Please rename the file and try again. " when I try to attach.
Paul M.
Post by: stirling on March 19, 2014, 04:20:15 AM
The upload problem is because the forum only allows a file with a given name to be uploaded once. i.e. someone has uploaded an xml previously with the name you were trying to use. Each time you upload a file it has to have a name that hasn't been used before. Anyway....
Your problem is that you have "Max CL mode enabled" ticked on your plasma profile. See ports n pins "ports setup and axis selection" tab and un-tick it.
Post by: signweld on March 19, 2014, 08:36:20 AM
Thank-you so much!  Instant fix. Let this be a lesson to me, that when comparing the 2 configuring screens (mill  -& plasma) to look for not only that settings are checked, but also that all others are un-checked.
Paul M.
